Dual Channel POV display
Two channel SERIAL POV led display.
Public Chat
This is an 8 bit ( led ) x 2 display, A Blue led display and a White led display.
Via slip ring +5 volt and 2 serial IN lines, one for the Blue and the other for the White leds.
Each display has its own ATmega to handle serial data in and timing / driving of the leds.
The PCB is laser printed paper glued to a bakelite or fiberglass blank PCB, then hand drilled with Dremel.
All Schematics, Arduino codes, and more details can be seen here at Instructables-- POV danno1802
https://www.instructables.com/DUAL-Channel-SERIAL-POV-Display/
U1_POV_v_3.8.3.ino
ino - 11.15 kB - 03/20/2023 at 19:28
Download
Happy_New_year_U2_White.ino
ino - 10.36 kB - 03/20/2023 at 19:28
Download
Time_Clock_POV_U2.ino
ino - 9.62 kB - 03/20/2023 at 19:27
Download
POV_brown_fox_v9_U2_WHITE_MIN.ino
ino - 12.71 kB - 03/20/2023 at 19:27
Download
U2_POV_v_3.7.7.ino
ino - 10.45 kB - 03/20/2023 at 19:27
Download
View all 8 files
RunnerPack wrote 03/23/2023 at 13:29 point
I love the concept of two, back-to-back, POV displays floating in mid-air! This is genius!
