Phat-Stats TFT V1.6.3 ATSAMD21
(requires HardwareSerialMonitor 1.3 Upwards)
Minimize blinking on screen data value changes and screen refresh.
CPU Turbo or GPU Boost Mode frequency gains. (eg: +895MHz) or gain %
Show when CPU or GPU is Throttling (Hit Thermal Junction Max temp)
Show when CPU or GPU Turbo or Boost Mode is active.
Add rotary encoder for PWM screen brightness.
there is a problem with the articles. What's the solution ?
https://resimyukle.tc/image/f22e1ecb-76aa-4951-9d73-e3aa79e0fda0.oySA
