The rules are as follows:
Size Parameters:
1. Max dimensions of structure: length = 20 cm, Width = 15 cm, Height = 20 cm
Other Parameter:
1. Max thickness of walls 1/4 of an inch
2. Structure can ONLY be made of paper and/or plastic NOT metal and/or wood
3. You must be able to take the egg out of structure after every trial.
4. You must be able to close the structure to keep the egg encased.
5. NO liquids/butters/puddings/ or Jell-O are to be used inside the structure.
Composites are allowed and I can use bolts to secure things
