Replaced the advil caps with a couple electrolytic capacitors of the correct value...
It Works!
- Hooked to a single AA + 5V boost module
- 260 - 300 mah from the AA = about 10 Hours per cell
- Oled at Full brighness
- Tx speed is up. 15Hz at idle (no conection)
- 70 Hz! Connected! (with no serial output.) did I count wrong in the code?
Will figure out a basic case and add Trim adjustments for the joysticks.
3/4 axis are off by +3...
Having multiple remotes should really speed up my other projects.
Now I can have more customized code on both rx/tx.
