• Projector Aligned
    Joshua Elsdon • 01/24/2017 at 15:50 • 0 comments
    Just a quick picture of the printer with projector mounted. Just a few connections to be made to the RPi for the end stops etc. Interestingly, (by design) the projector does not need to be modified for this build area, so this slightly larger design could be seen as 'easier' than the 'LittleRP' design where the focal distance needs to be reduced to allow it to focus on the small build plate.
  • Building the MDF Structure.
    Joshua Elsdon • 01/21/2017 at 17:44 • 0 comments
    Today we cut and assembled the MDF structure of the machine. There are a few errata to note (that I will update in the files at some point). The holes for the projector are not exactly right, we manually drilled them 6mm to the left (projectors point of view). Also the small front pannel below the door needed to be 6mm higher. (Please ignore this rubbish reporting, this is mainly notes to self ;) )
  • Initial Build
    Joshua Elsdon • 01/20/2017 at 23:18 • 0 comments
    Hello, I will update this post over the weekend with any interesting notes.
    The DXF files for cutting are attached to this project.
