The following code displays the gas sensor values on the AR glasses.
Note: Because the sensor is warming up,
the first 10-20 readings will always be
TVOC 0 ppb and eCO2 400 ppm.
#include <Arduino.h>
#include <U8x8lib.h>
#include <Wire.h>
#include "Adafruit_SGP30.h"
Adafruit_SGP30 sgp1; // Define two classes
Adafruit_SGP30 sgp2;
U8X8_SSD1306_128X64_NONAME_HW_I2C u8x8(/* reset=*/ U8X8_PIN_NONE);
void setup(void)
Serial.begin(9600);
u8x8.begin();
u8x8.setPowerSave(0);
// Start I2C communication with the multiplexer
Wire.begin();
// Init sensor on bus number 0
TCA9548A(0);
sgp1.begin();
// Init sensor on bus number 7
TCA9548A(7);
sgp2.begin();
void loop(void)
printValues(sgp1, 0);
printValues(sgp2, 7);
// Function to select I2C BUS
void TCA9548A(uint8_t bus)
Wire.beginTransmission(0x70); // TCA9548A address
Wire.write(1 << bus); // Send byte to select bus number
Wire.endTransmission();
// Function to display sensor values on the OLED
void printValues(Adafruit_SGP30 sgp, int bus)
u8x8.setFont(u8x8_font_7x14B_1x2_r);
TCA9548A (bus);
Serial.println(bus);
if(bus == 0) u8x8.drawString(2,10,"Inside: ");
else u8x8.drawString(2,10,"Outside:");
u8x8.drawString(2,20,"TVOC:");
sgp.IAQmeasure();
u8x8.setCursor(2,30);
u8x8.print(sgp.TVOC);
u8x8.print(" ppb");
delay(3000);
u8x8.drawString(2,20,"eCO2:");
u8x8.print(sgp.eCO2);
u8x8.print(" ppm");
delay(3000);
