Second PCB version ordered
A project log for Isetta TTL computer
TTL Retro computer runs 6502 and Z80 code. Has video, sound and filesystem. Runs a Windows-like OS. No microprocessor or FPGA.
roelhroelh • 10/19/2024 at 08:49•1 Comment
Yesterday I finally ordered the new PCB. This PCB is sponsored by the kind people of PCBWay, the well-known high-quality PCB fabrication company from China. During production you can always check in which production state your pcb is, and I watched an impressive series of videos that show all steps in the production process.
This is the KiCad 3D-impression of the new PCB:
With respect to the first PCB, the main changes are:
 - fix mistakes (VGA connector)
 - add Mouse connector
 - add HW for sending info to keyboard (and mouse)
 - add memory bank select
 - change video pixel/color generation for 640x400 mode
 - change WiFi module type
 - simple 4-wire connect to Raspberry Pi (for file transfer)
 - instead of a SPI header, a micro-SD card connector is mounted
 - changed SPI reading, it can now be done in 2 cycles/bit (instead of 5)
Eman Kafe wrote 10/23/2024 at 13:01 • point
I have read every log on your cpu designs in lurk mode ever since the first kobold. Very cool to see this becoming an actual product.
