Two weeks ago I was able to find a small carbon fibre manufacturer that is able to produce 8mm carbon fibre rods with a tolerance of 0,05mm. Lets find out if it's good enough for fast printing.
A project log for THE 100 - The fastest 3D Printer
based on a printed frame. The design is free, the parts needed are affordable and its easy to build
