Just made a video for the Hackaday Prize. Right now I'm too sleepy to talk about it, especially given that I accidentally the whole script, so I had to rewrite it 10 hours before, and some photos came to me at the last moment possible =(
Recently, I made a "How I use my ZeroPhone" worklog. It was really easy to write for me, I shared it on Reddit, got a lot of positive responses and some really good questions. Those questions prompted me to write two more worklogs - "Why ZeroPhone ships with 18650 batteries" and "Making ZeroPhone work as an actual phone". The first one was easy to write - the second one was noticeably harder =) Anyway, stay tuned for the next part of "How I use my ZeroPhone" - I hope it's going to be as easy to write as the first part!
Now, about project's contributors. @Ninjalicious has the first design of a ZeroPhone case!
It needs more work and testing, and we need to clean up files before we can publish them, but it already works as a case! Now, it does underline the ZeroPhone problem - it's really thick =D So, even though, as I mentioned, I can't use pouch cells as a default option, I will have to do more research on this and make sure it's an option that's reasonably accessible for people that don't have huge pockets.
I had a Nokia 6030 with a pair of ancient 17670 cells superglued at the sides and soldered in parallel to the original LiPo contacts (along with a bodge resistor for the missing thermistor so that it would even turn on). They nearly matched the thickness (18mm according to the big wiki). Of course it wasn't really a candy bar any more, being 75% wider, but it still went easilly into a jeans pocket by itself. The relatively huge radius of curvature at the new 'sides' probably helped. I didn't test the talk time but the standby time was pretty sweet-- week between charges, doing mostly SMS.
Have you considered anything like that? There are single-cell 18650 holders around, though you might want some kind of protective shell... I didn't bother, just wrapped enough black tape to cover the ends :D
Thanks for doing & documenting all this.
Looks like I was beat to designing a case... I was having 3D printer issues and just recently got it running again. I like this design - looks much better than what I had in mind. Where can I find the files to print or modify this myself?
Hey, the more cases we have, the better - this phone is unusual in a way of how it all fits together, so with more independent designs, we have more room for new decisions!
As for the file availability - that's a question to @Ninjalicious ( https://hackaday.io/ninjalicious ) . AFAIK the files were designed in Solidworks (I might be wrong, but the screenshots looked like it), and last time I asked, he wanted to make some modifications to it before releasing a version.
I can release STEP files right now.
Excellent, I'd love to see them.
