30mm steel against the GEDM - The final challenge
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
gedm-devgedm-dev 02/17/2024 at 06:410 Comments
PS: Most of the other cuts on the block where testcuts. The one G would have finished but the process is too slow and I had to edit the code. Can't wait for the full cut to finish every time.
Points so far:
30mm Steel: 200
GEDM: 1
The finish is insane.
The exit moment:
