The final boss is tamed.
Cutting a 30mm steel block with a cheap DIY wire edm machine is a quest that almost never ends. Almost.
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
