The new HGR15 tool-head and the XY axis are mostly done.
The new tool-head can take a Nema17 stepper and has an adapter to use a geared 12v DC motor. Two ball bearings should make the spindle very rigid.
A simple lever with ball-bearings is used as belt tensioner.
