First test with the new X axis and GRBL
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
gedm-devgedm-dev 06/28/2023 at 02:320 Comments
Just a small update:
The GRBL fork does work nice. The one axis sinker/drill part gives a stable burn and the first test with the x axis wasn't bad.
I'm still testing different ways for the XY motion. The one shown in the video stops the XY motion while the Z axis is adjusting.
The workpiece was clamped down very sloppy. With a solid vice this would have been a different quality. Lots of room to improve but all in all a very nice first cut.
I also had to stop the process since the workpiece was on the bottom of the plastic container and the electrode started scratching the plastic.
