The first custom single axis sinker EDM build running on G-RBL
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
gedm-devgedm-dev 10/02/2023 at 01:280 Comments
The first custom sinker EDM build running on G-RBL just emerged. It is a bare-bone build that doesn't use any G-EDM components except for the software.
It uses a custom stepper driver and a custom pulse generator running at about 100v.
Due to the different step resolution of this setup it will still need some finetuning.
Thumbs up!
