Firmware to run the G-EDM Gapstorm Board
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
gedm-devgedm-dev 04/29/2026 at 22:100 Comments
The new firmware is available on github now. This firmware is only compatible with the gapstorm board and upgraded EVOIII boards. A tutorial showing how to upgrade the EVOIII boards will follow soon. It is not hard and can be done by everyone with a soldering iron.
https://github.com/G-EDM/G-RBLv3
