I finally made some progress on the library for CircuitPython for controlling the smart servos. For now I only have the basics, and I don't support SYNC WRITE (though I do have WRITE and REG WRITE, so you can move them all at once). But you can already set the id, set target, speed and time, and read load, position and voltage/temperature. That's basically all we are going to need. The code goes something like this:
import struct
class ServoBus:
def __init__(self, uart):
self.uart = uart
def _chcecksum(self, data):
checksum = 0
for byte in data:
checksum = (checksum + byte) & 0xff
return checksum ^ 0xff
def send(self, servo_id, command, data=b'', reply=True):
buf = bytearray(len(data) + 5)
buf[0:1] = b'\xff\xff'
buf[2:4] = struct.pack('>BBB', servo_id, len(data) + 2, command)
buf[5:-1] = data
buf[-1] = self._chcecksum(memoryview(buf)[2:-1])
sent = self.uart.write(buf)
readback = self.uart.read(sent)
#print(readback)
if not reply:
return
b = self.uart.read(1)
while b == b'\xff':
if b is None:
raise RuntimeError("No reply")
reply_len = self.uart.read(1)[0]
reply = bytearray(reply_len + 3)
reply[0] = b[0]
reply[1] = reply_len
reply[2:] = self.uart.read(reply_len)
if self._chcecksum(memoryview(reply)[:-1]) != reply[-1]:
raise RuntimeError("Bad checksum")
return reply
def ping(self, servo_id=0xfe):
reply = self.send(servo_id, 0x01)
return reply[2]
def read8(self, servo_id, register, length=1):
reply = self.send(servo_id, 0x02, struct.pack('>BB', register, length))
return reply[3:-1]
def read16(self, servo_id, register, length=1):
reply = self.read8(servo_id, register, length * 2)
return struct.unpack('>' + 'H' * length, reply)
def write8(self, servo_id, register, *params, bulk=False):
write_command = 0x04 if bulk else 0x03
data = bytearray(len(params) + 1)
data[0] = register
data[1:] = bytes(params)
reply = self.send(servo_id, write_command, data)
return reply[2]
def write16(self, servo_id, register, *params, bulk=False):
data = bytearray(len(params) * 2 + 1)
data[0] = register
data[1:] = struct.pack('>' + 'H' * len(params), *params)
return reply[2]
def commit(self, servo_id=0xfe):
reply = self.send(servo_id, 0x05, reply=False)
class SCS0009:
def __init__(self, servo_bus, servo_id, reverse=False):
self.servo_id = servo_id
self.servo_bus = servo_bus
self.reverse = reverse
def set_id(self, new_id, permanent=True):
if permanent:
self.servo_bus.write8(self.servo_id, 0x30, 0)
return self.servo_bus.write8(self.servo_id, 0x05, new_id)
def set_torque(self, value, bulk=False):
return self.servo_bus.write8(self.servo_id, 0x28, value, bulk=bulk)
def set_target(self, value, bulk=False):
if self.reverse:
value = 1023 - value
return self.servo_bus.write16(self.servo_id, 0x2a, value, bulk=bulk)
def set_time(self, value, bulk=False):
return self.servo_bus.write16(self.servo_id, 0x2c, value, bulk=bulk)
def set_speed(self, value, bulk=False):
return self.servo_bus.write16(self.servo_id, 0x2e, value, bulk=bulk)
def get_position(self):
value = self.servo_bus.read16(self.servo_id, 0x38, 1)[0]
if self.reverse:
return value
def get_speed(self):
return self.servo_bus.read16(self.servo_id, 0x3a, 1)[0]
def get_load(self):
return self.servo_bus.read16(self.servo_id, 0x3c, 1)[0]
def get_voltage(self):
return self.servo_bus.read8(self.servo_id, 0x3e, 1)[0]
def get_temperature(self):
return self.servo_bus.read8(self.servo_id, 0x3f, 1)[0]
def commit(self):
return self.servo_bus.commit(self.servo_id)
Next up is to get the walking code to use this, and then see what improvements we can do to it using the time/speed settings.
deʃhipu
