Argentum compiler builds a DWARF-compatible debug info, And it's all integrated with VSCode:
- Ctrl+Shift+B builds and runs release versions.
- F5 - starts debugging sessions.
So far it supports:
- Variable and class inspection (including lambda capture blocks)
- Call stack + intermediate frames' variables and code locations
- Breakpoints
- Stepping through code.
It has special handling for pointers to functions, lambdas and delegates, strings and limited support for arrays (it shows only 20 first elements).
![](https://cdn.hackaday.io/images/567731685989640867.jpg)
So far it shows only static type of object by pointers. As a temporary work-around you can use watch expressions with type casts (they can also be used to access any array elements beyond 20 elements boundary).
All details are here: https://aglang.org/argentum-debugger-v1/
