ElectroLab
Transform your curiosity for electronics into creative circuits.
jonJon
The ElectroLab board is an educational electronic trainer designed to provide a guided and beginner-friendly approach to learning practical electronics. This versatile platform requires no prior knowledge and comes equipped with a large set of resistors and capacitors, multiple transistors, and a wide range of integrated circuits. With the ElectroLab, building your electronic circuits is made easy in just a few simple steps.
Want to get one?
If you want to get this board and its accessories, visit the product page at:
How does it work?
The ElectroLab board contains more than 50 different components grouped by blocks:
  • 30x Resistors (9 different values)
  • 20x Capacitors (10 different values)
  • 4x Diodes
  • 5x Transistors (3 NPN & 2 PNP)
  • 8x Operational amplifiers
  • 14x Logic gates (4 ANDs, 4 ORs & 6 NOT)
  • 4x JK Flip Flops
  • 1x Audio amplifier
  • 1x 555 signal generator
  • 9x pushbuttons
  • 1x resistive tactile sensor
  • 3x potentiometers (two rotors and one slider)
  • 1x microphone
  • 1x photoresistor (LDR)
  • 1x thermoresistor (NTC)
  • 1 triaxial accelerometer
  • 1x gas sensor
  • 1 nine-led bar
  • 1 RGB led
  • 1 7-segment display
  • 1 Speaker
By using this set of components, you can easily build your own circuit by connecting them directly with female-female DuPont wires to the corresponding pins of each component. The only limitation to the circuits you can create is your own imagination (and the availability of cables and boards, of course :D). These components have been thoroughly tested with various circuits that are ideal for learning basic electronics, such as:
  • Oscillators with transistors, resistors, and capacitors
  • Circuits with Op. Amps (sum, diff, integrator, etc)
  • Analog to Digital converter with Op. Amps
  • Combinational circuits with logic gates
  • Sequential circuits with Flip Flops
  • Counters with Flip Flops
  • Binary to Decimal converter
  • Square signal generators with the 555
  • Timer with the 555
  • Politone keyboard
  • Audio amplifier with low/high passes
  • Volume indicator with LED bar
  • Horizontal level indicator with LED bar
The story behind ElectroLab
ElectroLab’s story goes back to 2016. By then I was finishing my engineering degree and working as content creator and course coordinator for the Technological Campus of ICAI (CTI). This summer campus takes place in Madrid during 4-6 weeks and is addressed to pre-university students in the 14-18 years old range. The courses offered on the campus are normally 1-week duration 6h/day and aim to cover the basics of a specific topic (ie: robotics with Arduino, videogame design) in a very interactive and easy-to-follow way based on praxis and experimentation.
Among the courses I used to coordinate back then, the one on Electronics felt especially interesting for me: I wanted to offer a solid basis and at the same time let my students experiment in a safe way with each newly acquired concept. But the most important was to make it fun.
I had around 8 months to come up with the contents, the workshops, and most important: the electronic platform where to experiment with the course content (sensors, electronic components, etc). Back then, my experience pushed me away from breadboards, not because they were not a good solution, but because in a class filled with more than 10 students, debugging the mistakes committed on a breadboard (bad connections, components pins damaged by extensive usage, polarity misconnections) could become unsuitable for the given time.
Since it was the first edition of the Electronics course and we were not sure if it would succeed, the possibility of acquiring expensive and heavy electronic trainers was neither an option.
Instead, I kind of mixed both concepts in a compact, yet powerful, solution: the ElectroLab, a 175x100mm board that had on the top side the (male) pins and connectors for each component and on the bottom all the SMD components routed to each corresponding pin and ready to be used.
First generation (2016) of the board on the left, second generation (2020) on the right
ElectroLab Mk. I (V1)
The very first prototype of the ElectroLab cannot be considered one of my finest jobs. Except for the simplest components, most of the ones that required some kind of circuitry preparation didn't work correctly: the op. amps were not correctly powered, the flip flops and the logic gates had no pulled-down inputs (so were reading static noise while not receiving...
  • ElectroLab Mk. III available!
    Jon • 10/16/2023 at 21:48 • 0 comments
    As a result of the new design of the Mk. III, the ElectroLab is able to leave the limited environment of the Campus and get ready to be affordably purchased as a solderable kit.
    If you have some soldering skills and want to spend some time assembling and soldering the latest electronic trainer, get yours on Elecrow!
View project log
