Features:
  • Responsive Touch GUI with support for landscape and portrait orientations
    • Turn shelf on/off, adjust brightness, painting tools, trigger animations
    • Runs synchronized on embedded touchscreen and multiple Android/PC devices
    • Runs in-process or standalone
  • SK9822/APA102 LED paint engine supporting gamma correction and HSV-based brightness derivation
  • Animation framework
    • Fireplace animation 🔥
  • Embedded display backlight control with MCU-generared PWM signal
    • Smooth display fade-in on user interaction, fade-out on idle timeout
  • HTTP REST API
  • CLI frontend utility `hyelichtctl` (HTTP-based), works locally and over the network
  • Philips Hue smart lights integration: HTTP-based plugin for the diyHue open source bridge emulator
  • systemd integration (service unit)
  • Doxyen-based documentation
  • REUSE- and SPDX-compliant free software written in C++17 and QML
