Got a bit distracted with the IO project ( Now how can that happen ) and decided to wire up a new ( for me ) flip flop circuit. Yann has wanted me to ditch the 555 as a clock and the pulser circuit from the start and now is the time :-)
By using a master slave flip flop I can get rid of the pulser and replace the master NOR flip flop with a Nand logic master slave. This is also the start for building a 4017 Johnson Counter using this master slave :-)
And here is a video of the new flip flop in action as well as using the new clock circuit.
