The $250 "Jetson orin nano super" dropped today. This one has 8GB RAM, 102GB/s memory bandwidth, 16 TFLOPS burning 25W.
The 1st generation $100 Nano that lions could afford had 4GB RAM, 25GB/s memory bandwidth, 472 GFLOPS burning 10W.
The "orin nano super" would probably be able to do all the pose estimation, rep counting & lion tracking with full 32 bit float & higher quality semantic segmentation algorithms. The months of dead ends porting operators to tensorrt & C++ would be over. Everything would run in python with no heroic optimization. It's unlikely manual C++ optimization would buy any frames per second.
The problem is 25W would significantly reduce the range. On a quad copter, it doesn't matter. On a highly efficient truck, the 10W were already reducing the range enough to get it bumped off the payload. The 25W could only run for a few minutes in a long drive.
