The gears responsible for opening the petals were designed using a gear simulator, which we modified to suit our project requirements. Some modifications included removing certain teeth and adding a hole in the center. Throughout the process, we encountered challenges with the dimensions and had to make multiple attempts to achieve the desired outcome.
![](https://cdn.hackaday.io/images/966271686656173034.jpeg)
![](https://cdn.hackaday.io/images/5042731686656173043.jpeg)
![](https://cdn.hackaday.io/images/1572421686656173803.jpeg)
