After a lot of work, the project is finally put together. As I write these lines, we still have some problems, notably a part which, if it turns too low, destroys the movement. We are therefore adding a small metal piece to block the piece.
Our last problem being the engine which is surely too powerful and will break the gears. The solution to this problem will be found tomorrow. No choice
