After using various registers settings borrowed from STANDARD.BNK included with adlib visual composer I decided on something which doesn't exactly sounds like lasers, but does a bit nicer.
Unfortunately I have now ran out of time and space so uploaded some binaries to this project page.
The scan1 or scan2 part in the filename indicates the scancode set used. Scan1 works in bochs, scan2 in qemu.
You can run one of the images using these emulators as follows:
$ qemu-system-x86_64 -bios image.bin -soundhw adlib$ bochs 'romimage: file=./image.bin'The image are 64KB in size since that's the minimal size for a valid ROM image (or atleast to these emulators). The images with a demosong are oversized, but save you the hassle of actually using the tracker.The images without demosong contain 1016 bytes of actual data, the zero initialized aren't used.
Memory Configuration
Name Origin Length Attributes
*default* 0x0000000000000000 0xffffffffffffffff
Linker script and memory map
.text 0x0000000000000000 0x3e8
*(.text)
.text 0x0000000000000000 0x4a bitdec.o
*(.rodata)
.rodata 0x000000000000004a 0x39e bitdec.o
.init 0x000000000000fff0 0x10
*(.init)
.init 0x000000000000fff0 0x10 bitdec.o
.data 0x0000000000010000 0x0
.data 0x0000000000010000 0x0 bitdec.o
.bss 0x0000000000004000 0x0
*(.bss)
.bss 0x0000000000004000 0x0 bitdec.o
LOAD bitdec.o
OUTPUT(bitdec.bin binary)
michaelschrijver
