Installation of Home Asssistant will require a Linux operating system.
If you are on a windows PC then you will need to install virtualisation into this system.
This may seem to be complex, but frankly speaking it is not !
You even have several options. I did choose the first one: installing VirtualBox to run a VDI image of home assistant
![](https://cdn.hackaday.io/images/7698621681889158688.jpg)
I will go through this installation process, but if you want you can choose any other solution!
- click on the virtualBox.vdi link above and download the home Assistant virtual machine image
- go to VirtualBox site and search for the version suitable for your operating system
![](https://cdn.hackaday.io/images/5691501681889520245.jpg)
For my very old PC (more than 12 years old) I had to go to the "Old_builds" section and select the latest release working for 32 bits OS... It was the 5.2 versions and more specifically the 5.2.44
I must admit that I was a little afraid to install such an old "unsupported version" on my PC but it worked without any issue.
Install it and run it.
You should see a windows like this one
![](https://cdn.hackaday.io/images/6562801681892763614.jpg)
Click on the top left button to create a new virtual machine
![](https://cdn.hackaday.io/images/6405221681892818560.jpg)
then:
- name your machine as you want, select Linux OS and latest 4.X (64bits) version
- then choose your home assistant virtual machine image
- open it
When done click on the configuration button.
you have to go to the "system" tab and activate the EFI option into your virtual mother board
![](https://cdn.hackaday.io/images/4129791681892992056.jpg)
Then go to the "network" menu and select the "bridge" option. You will need to connect your PC to your network (wifi is not supported)
![](https://cdn.hackaday.io/images/5160721681893245255.jpg)
And that's it.
You can now start your Virtual machine with the big green arrow. After a while Home Assistant will be launched into VirtualBox. Your home assistant server is running.
![](https://cdn.hackaday.io/images/2242211681893306894.jpg)
Now launch its web interface using your browser and typing the given URL http://homeassistant.local:8123
Your home assistant is indeed accessible on your local network. This is a safe way for the moment. But iti is of course possible to expose HA on internet. This will be explained later.
![](https://cdn.hackaday.io/images/4900521681893487452.jpg)
after a few minutes, you can now "onboard" home assistant
![](https://cdn.hackaday.io/images/82891681896708894.png)
select any name and credentials you want!
and a new "home" is on your screen
![](https://cdn.hackaday.io/images/5632671681894225576.jpg)
Well it's an "empy" home into which we will now add a Rezodo system !
