Once again we will use Home assistant integration to add the calendar.
![](https://cdn.hackaday.io/images/5079751682005975758.jpg)
Click the add an integration
![](https://cdn.hackaday.io/images/5038771681920506368.jpg)
and into the search bar look for "calendar" and you will find the localCalendar add-on.
![](https://cdn.hackaday.io/images/4429461682005595979.jpg)
select it and install the calendar with the nice name "Rezodo"!
![](https://cdn.hackaday.io/images/5811841681920768297.jpg)
Valid and you get a new integration: the Rezodo calendar
![](https://cdn.hackaday.io/images/8869661682005697933.jpg)
You now have a calendar tab into the left menu that will open your calendar.
You can have as many calendars you want. For now one is enough: "Rezodo". It's a very clean calendar into which you can add events on specific days/month/year hour minute... with optionnal repetition/exclusion. Well something more or less like the Google Agenda but devoted to home automation.
![](https://cdn.hackaday.io/images/8278441682005837079.jpg)
