A new board for Rezodo : 6 irrigation valves + ESPNow
A project log for Rezodo: Long Range irrigation and weather station
Rezodo aims at building a distributed irrigation system and a weather station with farmers. It's also a fully open platform for IoT learning
jp-gleyzesJP Gleyzes • 04/28/2023 at 14:29•0 Comments
Just an illustration of Rezodo flexibility: here is another board fully compatible with Rezodo network:
The PCB is available on shared Project at PCBWay: https://www.pcbway.com/project/shareproject/Rezodo_Long_Range_irrigation_and_weather_station_ESPNow_module_with_6_valves_5eba33d4.html
And thank you PCBWay for sponsoring this board !
Schematics are pretty much the same as 4 valves board but with one coil driver more and Lora less!
The board is extremely compact, both sides are soldered with DIY modules.
