Hi everyone,
It's early spring and the prototype is still outside chasing the sun!
The bad weather ruined the plywood a bit but the circuit and the engines withstood the rain and cold.
From a mechanical point of view we had to:
- replace a damaged nut (inside the actuator)
- replace the collar that supports the panels
during the winter, when the sun was available, we were able to charge a power bank, which is proving to be a convenience!
My Solar Tracker
