Behold: The Audio Navigation Module
A project log for "Mercator Origins": Sat Nav & Telemetry for Divers
Want to map your dive? Want to navigate like a pro? Even if you are vision-impaired, this will empower you to navigate our underwater world.
mark-b-jonesMark B Jones 05/30/2023 at 11:180 Comments
This is the back of the audio module. You can see from top left, clockwise:
1. The surface exciter that vibrates the enclosure to produce sound underwater.
2. The Beetle ESP32-C3 (RISC-V) microcontroller.
3. The BH1750 Lux/Light sensor - TBD.
4. The DFRobot MAX98375 I2S Amplifier module
This is the back of the audio module, from top-right clockwise:
1. The blue solid-state 1 Amp fuse.
2. Adafruit VL53L4CX Time of Flight Sensor - to alert diver if they are too close to the lake/sea-bed.
3. Lithium rechargeable battery (charged through battery charging circuit in the Beetle ESP32-C3)
4. Not visible, buried in the middle! The Adafruit Micro SD Card breakout PCB.
Rich text editor
