---> Click there for Mercator Origins Code Repos <----
All code has been developed using the Arduino IDE, hence the monstrously sized INO file for each of the three mercator-origins projects. Lots of tidying up to do, the major one will be moving to VS Code environment which may only happen in June.
These are the repos: (top three all named after shark species!)
mercator-origins-lemon
the code running on the M5 Stick C Plus is the yellow float at the sea surface that connects to the GPS, connects to the internet via WiFi hotspot and connects the diver console with the sub-sea up/down link.
mercator-origins-mako
The code running on the M5 Stick C Plus in the diver's console gopro enclosure that is running the navigation and guidance software. It also has all sensors (except leak detector) wired into it.
mercator-origins-tiger
The clock/uptimer/downtimer shown on the second M5 Stick C Plus in the console go-pro enclosure. Connects to the leak detector only at present.
