Week 2: Today we took a break from designing the housing for this system's components and continued working on the programming attempting to get the LEDs to light up at the correct time. On day 7 We worked on getting the LEDs lit in the right place and started working on getting the ball to move, we also decided to scrap our idea for the housing of the game. On the eighth day of this assignment, we got our ball rolling and we started on getting the blocks to disappear when the ball makes contact with them, we started the housing redesign and decided to have the display vertical instead of our original plan of it being horizontal. On day 9 we finished our housing and are working on getting it 3d printed, we also started working on turning each box into there own separate variables, another thing we did on the ninth day of our project is we went back to having the displays set vertically because we would not be able to 3d print the housing to hold them vertically due to the trouble of getting cables to run through correctly and due to the fact that you cant print over the air.
