First, it looks like this connector there is a parallel port. It is connected to a PACSZ1284 chip so there might be something to do with this later!
And a few information about the hardware from the OS:
lspci
root@rsfo-ntp01:~# lspci 00:00.0 Host bridge: Intel Corporation Mobile 915GM/PM/GMS/910GML Express Processor to DRAM Controller (rev 04) 00:02.0 VGA compatible controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 04) 00:02.1 Display controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 04) 00:1c.0 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 1 (rev 04) 00:1c.1 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 2 (rev 04) 00:1d.0 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 04) 00:1d.1 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 04) 00:1d.7 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 04) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev d4) 00:1f.0 ISA bridge: Intel Corporation 82801FBM (ICH6M) LPC Interface Bridge (rev 04) 00:1f.2 IDE interface: Intel Corporation 82801FBM (ICH6M) SATA Controller (rev 04) 00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 04) 02:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection 03:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
lscpu
root@rsfo-ntp01:~# lscpu Architecture: i686 CPU op-mode(s): 32-bit Byte Order: Little Endian Address sizes: 32 bits physical, 32 bits virtual CPU(s): 1 On-line CPU(s) list: 0 Thread(s) per core: 1 Core(s) per socket: 1 Socket(s): 1 Vendor ID: GenuineIntel CPU family: 6 Model: 13 Model name: Intel(R) Celeron(R) M processor 1.50GHz Stepping: 8 CPU MHz: 1500.033 BogoMIPS: 3000.06 Vulnerability Itlb multihit: KVM: Mitigation: VMX unsupported Vulnerability L1tf: Mitigation; PTE Inversion Vulnerability Mds: Vulnerable: Clear CPU buffers attempted, no mic rocode; SMT disabled Vulnerability Meltdown: Mitigation; PTI Vulnerability Mmio stale data: Unknown: No mitigations Vulnerability Retbleed: Not affected Vulnerability Spec store bypass: Vulnerable Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization Vulnerability Spectre v2: Mitigation; Retpolines, STIBP disabled, RSB fil ling, PBRSB-eIBRS Not affected Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtr r pge mca cmov clflush dts acpi mmx fxsr sse ss e2 ss tm pbe nx bts cpuid pti
lsusb
root@rsfo-ntp01:~# lsusb Bus 001 Device 002: ID 18d1:4ee7 Google Inc. Nexus/Pixel Device (charging + debug) Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
sensors-detect (after installing lm-sensors and i2c-tools). Unfortunately, the "sensors" command doesn't show any sensor, yet...
Now follows a summary of the probes I have just done. Just press ENTER to continue: Driver `w83627hf': * ISA bus, address 0xa00 Chip `Winbond W83627THF/THG Super IO Sensors' (confidence: 9)
i2cdetect
root@rsfo-ntp01:~# echo i2c-dev >> /etc/modules
root@rsfo-ntp01:~# systemctl restart kmod
root@rsfo-ntp01:~# i2cdetect -l
i2c-3 i2c i915 gmbus panel I2C adapter
i2c-1 i2c i915 gmbus ssc I2C adapter
i2c-6 i2c i915 gmbus dpd I2C adapter
i2c-4 i2c i915 gmbus dpc I2C adapter
i2c-2 i2c i915 gmbus vga I2C adapter
i2c-0 smbus SMBus I801 adapter at 0400 SMBus adapter
i2c-5 i2c i915 gmbus dpb I2C adapter
root@rsfo-ntp01:~# i2cdetect -y 0
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: 08 -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- 44 -- -- -- -- 49 -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- 61 -- -- -- -- -- -- -- 69 -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@rsfo-ntp01:~# i2cdetect -y 1
00: -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
root@rsfo-ntp01:~# i2cdetect -y 2
root@rsfo-ntp01:~# i2cdetect -y 3
root@rsfo-ntp01:~# i2cdetect -y 4
root@rsfo-ntp01:~# i2cdetect -y 5
00: 08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: 30 31 32 33 34 35 36 37 38 39 3a 3b 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d 5e 5f
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
root@rsfo-ntp01:~# i2cdetect -y 6
Let's execute "sensors" again:
root@rsfo-ntp01:~# sensors w83627thf-isa-0a00 Adapter: ISA adapter in0: 1.29 V (min = +0.70 V, max = +1.87 V) in1: 3.31 V (min = +0.72 V, max = +0.05 V) ALARM in2: 3.22 V (min = +2.61 V, max = +3.82 V) +5V: 4.96 V (min = +1.52 V, max = +2.19 V) ALARM in4: 3.58 V (min = +2.67 V, max = +2.30 V) ALARM 5VSB: 4.91 V (min = +0.05 V, max = +6.69 V) Vbat: 3.23 V (min = +0.96 V, max = +2.43 V) ALARM fan1: 7031 RPM (min = 907 RPM, div = 8) fan2: 7031 RPM (min = 2596 RPM, div = 8) fan3: 7336 RPM (min = 1622 RPM, div = 8) temp1: +32.0°C (high = +98.0°C, hyst = +12.0°C) sensor = thermistor temp2: +28.5°C (high = +80.0°C, hyst = +75.0°C) sensor = CPU diode temp3: +39.0°C (high = +80.0°C, hyst = +75.0°C) sensor = thermistor beep_enable: enabled
