RFEV - another quadruped robot
Yet Another Quadruped Robot, Jetson Nano, ROS2, 12 DoF
Public Chat
This is (yet another) a quadruped robot built from scratch. The goal from the controller standpoint is to use the Jetson Nano microcontroller from Nvidia with its 128 GPU cores to aid in image processing and AI capabilities, and to use the ROS2 robot operating system. For the physical robot I wanted 12 DoF and also a pan/tilt camera. I designed the legs and housings myself in Fusion360 based on ideas found online. Feel free to suggest improvements or tell me that they're awful.
The frame is made using 10mm x 10mm aluminum extrusion from a Makerbot kit.
The microcontroller is an NVidia Jetson Nano 4GB dev kit
The 12 leg servos are MG996R servos
The 2 camera servos are SG90 servos
The camera is a simple Arducam 5mp camera
I use the PCA9685 PWM controller to drive the 14 servos, connected to one of the I2C connectors (2 pins) on the Nano
Right Holder.stl
Right side tilt servo holder
Standard Tesselated Geometry - 63.27 kB - 04/18/2023 at 15:52
Download
SG90 Plate v7.3mf
The camera plate that fix the typical-sized Arducam RP camera and attaches to the tilt servo
3mf - 108.18 kB - 04/18/2023 at 15:52
Download
Left Holder.stl
Left side tilt servo holder
Standard Tesselated Geometry - 59.75 kB - 04/18/2023 at 15:52
Download
SG90 Pan Tilt Horn Base v2 v4.3mf
Base plate for the pan/tilt mechanism that the pan servo attaches to
3mf - 84.66 kB - 04/18/2023 at 15:52
Download
Jetson Nano Base v11.3mf
The base for the Jetson Nano DEV kit. My kit was the 4GB/B01 board but it should also fit the older 2GB/A02 version
3mf - 165.38 kB - 04/18/2023 at 15:45
Download
View all 14 files
  • 1
    Installing ROS2 on the Jetson Nano
    Using Jetpack 4.4 which runs Ubuntu 18.04. We install ROS2 Foxy. I tried Humble but it requires 20.04 or later. https://richardsand.com/?p=1634
View all instructions
