While doing a few final checks, I thought I'd check the currents from the opamp.
Whoa! The current is going plus and minus!
![](https://cdn.hackaday.io/images/3825291682269390608.png)
This makes total sense, the output of the opamp is designed to sink AND source current. We only want it to source current. Adding a diode to the output of the opamp will solve that.
![](https://cdn.hackaday.io/images/55011682269540403.png)
Much better, current is only going in one direction now.
![](https://cdn.hackaday.io/images/7421201682269752061.png)
And our new kiCAD drawing:
![](https://cdn.hackaday.io/images/7627661682479192876.png)
