Features & Specifications
- Operating Voltage:
- Main Power Input: 12 V to 42 V DC [Connect to 12 V Lead Acid Battery] ⚡ Has Reverse Polarity Protection
- Backup Battery Input: 3.7 V to 4.2 V DC [Connect a single cell 3.7 V - 4.2 V Li-Po or Li-Ion Battery] ⚠ Doesn't have Reverse Polarity Protection
- Dimensions:
- With Enclosure: Length: 52 mm * Width: 65 mm * Height: 30 mm
- Bare PCB Dimensions: Length: 34 mm * Width: 43 mm * Thickness: 1.6 mm
- Cellular module:
- A7672S - 4G-LTE-CAT1 / 2G - For India & Asia
- A7672E - 4G-LTE-CAT1 / 2G - For Europe
- A7672SA - 4G-LTE-CAT1 / 2G - For South America & Australia
- SIM7672NA - 4G-LTE-CAT1 for North America
- Antenna:
- 📶 Cellular: U.FL Connector 1.5 dBi gain Flexible PCB antenna comes attached
- 🛰 A7672x GNSS: U.FL Connector, Patch antenna comes attached, (External GNSS is enabled on request only)
- ESP32 Wi-Fi & Bluetooth Antenna: 2.4 GHz Chip antenna provided on board
- Battery Support: 3.7 V - 4.2 V DC Li-Po backup battery is supported. Use > 400 mAH capacity battery. MP2617 charger chip is used to handle the battery charging.
- Navigation hardware: Inbuilt GNSS of A7672x. A7672x has inbuilt GNSS hardware which needs passive or external active antenna [Bias is already provided to the GNSS U.FL connector]
- Operating Modes: HTTP, MQTT
- Configuration Methods: USB / Bluetooth
- Processor: Espressif ESP32 - C3FH4 RISC-V chipset
- Motion Sensor: LIS3DH 12-bit, 3-axis Accelerometer
- Memory: 4 MB inbuilt flash of ESP32 - C3FH4
- Connectivity: Bluetooth, GPRS, SMS, Call
- SIM connector: Nano SIM card connector
- Flashing options: Micro USB
- Enclosure: (Optional) Standard IP67 rated enclosure
- Indicators: 3x WS2812 RGB LED indicators for battery, network & location information
raviypujar
Davide Raggini
Norbert Fekete
mihai.cuciuc
jacopops
