NeuralDuino - dynamic and user reconfigurable
I'm creating a neural networks library for the arduino (easily portable to any other platform) that is user-reconfigurable to the core
I started this journey sometime in november to build a neural networks library in which i had the ability to actually change how my neurons are connected so that i could ommit connecting a few neurons and maybe connect some from a different layer, the basic intent being ensuring complete user-reconfiguration instead of just the ability to change NUM_LAYERS ,NUM_UNITS etc. LOL . so this project should benefit to all the ANN enthusiasts who wanted to do an ANN on the arduino UNO or above.
Developing a library wherein the users can play with the neurons themselves, connect those wherever and however they want.
Features:
1. choose your own activation function from the main sketch for each neuron individually
2. connect the neurons to each other as you like
3. each neuron is an object and whatever network you draw on the paper can be realized with this library
4. layer management given to the user (will have a default layer manager in the library in the future but not now, also there are enough examples to get anyone started)
5. Lots of examples ;-P
  • 1 × Arduino UNO and above
  • AWESOME !!! ANN on arduino works :-)
    Pranav Gulati01/19/2017 at 19:32 0 comments
    The beauty of a library is when changing the architecture of a neural network is easy enough to be implemented in the arduino sketch itself.
    so with the suggestions by t3db0t on issue (https://github.com/t3db0t/Neuroduino/issues/1) i implemented the architecture of the neural network shown in the link in the issue and VOILA!!! the XOR converged beautifully
    the best part about it was that i had to make no changes in the library whatsoever which actually strengthens and validates the need of such a reconfigurable library for neural networks on the arduino
    thanks to t3db0t :-)
  • Added Momentum parameter
    Pranav Gulati12/25/2016 at 12:24 0 comments
    Added the momentum parameter to the network (not as an option though, will mayb do that if it has undesirable effects)
    but adding momentum hasnt helped the XOR problem still , now i think i need help solving the XOR problem because i wont be able to sleep peacefully without making a perfectly working library so
    Please HELP !!
  • It works......Almost ;-P
    Pranav Gulati12/24/2016 at 05:10 0 comments
    the library i think is up and running , i tested it with the linearly separable test cases AND OR gates etc and have added the examples for the same
    Also made a counting example that takes input in 2 digit binary and outputs a decimal number one greater than the decimal equivalent of the binary (e.g input {1,1} output =4 ; input={0,1} output=2)
    the XOR problem still gets stuck at output values of 0.5ish, looking into it though
View all 3 project logs
Rich text editor
Pranav Gulati wrote 01/20/2017 at 08:06 point
http://www.alanturing.net/turing_archive/pages/reference articles/connectionism/Turing's neural networks.html
interesting, this library could actually be a step in making B-type networks, awesome
