![](https://cdn.hackaday.io/images/9473181682116387692.jpg)
The 'pro's original battery puffed after its firmware crashed & left it powered on overnight. The 'pro 7 can't run on USB power like the 4 did so there's been a need for a dummy battery.
![](https://cdn.hackaday.io/images/476031682116447649.jpg)
The journey begins by tearing off the label, reveling a metal skin.
![](https://cdn.hackaday.io/images/3128101682116498095.jpg)
Under the metal skin, we have B for battery in a lot of potting compound.
![](https://cdn.hackaday.io/images/2105741682116570711.jpg)
The potting compound breaks off, liberating the bottom.
![](https://cdn.hackaday.io/images/414601682116618327.jpg)
The top hinges open, revealing the tabs.
![](https://cdn.hackaday.io/images/9005991682116668523.jpg)
The tabs can be knifed off, liberating the brain board.
![](https://cdn.hackaday.io/images/4515541682116727353.jpg)
The brain board has the contacts. The mane problem is creating a new enclosure.
![](https://cdn.hackaday.io/images/747651682117102162.jpg)
All lion cameras sit inside another enclosure so the battery door could be removed. The door isn't removable like on a DSLR. The most long lived solution is to leave the door open & build the enclosure around it.
![](https://cdn.hackaday.io/images/3428221682117434580.jpg)
Maybe there's a space to grind away part of the door to poke cables through, but it's too destructive for now.
A small hole in the enclosure worked.
![](https://cdn.hackaday.io/images/2447801682141530446.jpg)
The problem is keeping the dummy battery inserted when using the user interface. The screen can't be accessed with camera locked in because there's a cooling fan.
There's no plan to use a pole with a dummy battery & cables running down the pole. It would only use a dummy battery on a tripod.
