About the Game
Dungeons of Daggorath was a very popular first-person RPG in the early 1980s. It was compatible with the Tandy TRS-80 Color Computer 1/2/3.
It was a very early three-dimensional game that allowed the player to explore a dungeons and battle monsters via a text based interface. That interface is used to move around, fight, pick up or use items, and much more. However, the vast majority of the time, the commands entered revolve around moving and attacking.
For these common actions, the text-based interface can be a bit slow and clunky, so I modified the source code to enable the right joystick (I always wished this was possible as a child). Moving the joystick moves the player around the dungeon, just as would be expected. The button triggers the command ATTACK RIGHT.
Being a first-person game, I could not resist the temptation to insert a few Doom characters in place of some of the originals. The CoCo may not be able to play Doom, but it kinda-sorta can do something like it.
I also gave the player unlimited power and health, which is great for exploring and testing, but that boost can be left out for those that want the challenge.
After assembly, the binary can be burned to a ROM chip mapped into the cartridge port, or should also work with any decent emulator. I assembled the source code with LWASM.
Speaking of source code, the former CEO of DynaMicro, Inc. very graciously released the source code for public distribution, but only in its original form. Since I have modified it, I cannot distribute my work. However, one can still recreate Dungeons of Doom without too much trouble by:
  1. Downloading the original 6809 source code.
  2. Making the modifications I have listed below.
  3. Assembling the code.
Media
Screencaps of modified enemies:
For comparison:
Playing on my CoCo 2:
Modifications to the Original Source Code
After line 623, insert the following:
TEMP1   RMB     1                ; NAB
BAGP    RMB     2                ; NAB
Replace line 13 with:
LBNE    PLAY20          ;   yes ; NAB: BNE to LBNE
On line 17, insert the follwing code after the PLAY10 label:
        ; NAB - check for joystick input.
        ; Joystick button.        LDA     65280        ANDA    #1        CMPA    #0        BNE     NOBUTTONPRESS                ; Attack right.        LDU     #PRHAND        JSR     ATTACKRIGHT        JMP     NOMOVE
NOBUTTONPRESS
        JSR     [$A00A]         ; BASIC joystick reading routine.
        LDA     $015B           ; Right joystick y-axis        CMPA    #10        BHI     NOMOVEFORWARD
        ; Move forward        JSR     PMOVEFORWARD        JMP     NOMOVE
NOMOVEFORWARD        CMPA    #50        BLO     NOMOVEBACKWARD
        ; Move backward        JSR     PMOVEBACKWARD        JMP     NOMOVE
NOMOVEBACKWARD        LDA     $015A           ; Right joystick x-axis        CMPA    #10        BHI     NOMOVELEFT
        ; Move left        LDB     PDIR        JSR     PMOVELEFT        JMP     NOMOVE
NOMOVELEFT        CMPA    #50        BLO     NOMOVE
        ; Move right        LDB     PDIR        JSR     PMOVERIGHT
NOMOVE        ; NAB - END check for joystick input.
Replace line 47 with:
LBRA    PLAY10         ;loop ; NAB - BRA to LBRA
This is optional, if you want infinte health. After line 40, add:
        CLRA                    ; NAB - IDDQD        CLRB        STD PDAM
After line 284, add:
        CLR     TEMP1
This is optional, if you want infinite power. After line 288, add:
        LDA     #$7F            ; NAB - Max power.        STA     PPOW
After line 11, add this label:
ATTACKRIGHT
After line 20, add the label:
PMOVELEFT
After line 29, add the label:
PMOVERIGHT
After line 153, add the label:
PMOVEFORWARD
After line 166, add the label:
PMOVEBACKWARD
On line 16, insert the following after the SOUNDI label:
; NAB - sound back on (reading joystick turns it off)        STA     TEMP1        LDA     $FF23        ORA     #8        STA     $FF23        LDA     TEMP1
Replace line 198 with:
SNRAT1  LBSR     SNOISE          ;get a random noise value ; NAB - L
Replace line 279 with:
SNWSH2  LBSR     SNZNVA          ;get some noise ; NAB - L
Replace line 285 with:
SNWSH1  LBSR     SNENVN          ;decompression subroutine ; NAB - L
On line 309, after the SNOUT label, insert:
On line 320, insert after the SNOISE label:
Replace lines 411-412 with:
        LBLS     SNCLK4          ; ; NAB - L        LBRA     SNOUT           ; ; NAB - L
Replace the spider vector list with:
;       Body
SPIDER  SVORG   40,100        SVECT   40,105        SVECT   42,115        SVECT   52,125        SVECT   60,128        SVECT   68,125        SVECT   78,115        SVECT   80,105        SVECT   80,95        SVECT   78,90        SVECT   68,80        SVECT   60,77        SVECT   52,80        SVECT   42,90        SVECT   40,100        SVNEW
;       Eye        SVORG   50,101        SVECT   52,106        SVECT   56,106        SVECT   58,101        SVECT   56,96        SVECT   52,96        SVECT   50,101        SVNEW
;       Pupil        SVORG   53,99        SVECT   53,103        SVECT   55,103        SVECT   55,99        SVECT   53,99        SVNEW
;       Mouth        SVORG   64,90        SVECT   64,95        SVECT   64,101        SVECT   64,105        SVECT   64,112        SVECT   69,114        SVECT   73,110        SVECT   74,101        SVECT   73,92        SVECT   69,88        SVECT   64,90        SVNEW
;       Teeth        SVORG   65,95        SVECT   70,97        SVECT   65,99        SVNEW        SVORG   65,103        SVECT   70,105        SVECT   65,107        SVNEW        SVORG   71,99        SVECT   66,101        SVECT   71,103        SVNEW
;       Horns        SVORG   44,118        SVECT   40,124        SVECT   35,127        SVECT   45,127        SVECT   50,123        SVNEW
        SVORG   44,87        SVECT   40,81        SVECT   35,78        SVECT   45,78        SVECT   50,82        SVNEW
        SVORG   40,108        SVECT   35,111        SVECT   41,114        SVNEW
        SVORG   40,97        SVECT   35,94        SVECT   41,91        SVEND
; End of Spider vector list
Replace the viper vector list with:
VIPER
;       Head        SVORG   55,120        SVECT   55,130        SVECT   55,140        SVECT   62,147        SVECT   69,140        SVECT   75,140        SVECT   83,140        SVECT   83,130        SVECT   83,120        SVECT   75,120        SVECT   69,120        SVECT   62,113        SVECT   55,120        SVNEW
;       Eyes        SVORG   62,118        SVECT   66,124        SVECT   66,129        SVECT   62,123        SVECT   62,118        SVNEW
        SVORG   62,142        SVECT   66,136        SVECT   66,131        SVECT   62,137        SVECT   62,142        SVNEW
;       Mouth        SVORG   70,122        SVECT   70,130        SVECT   70,138        SVECT   78,138        SVECT   78,130        SVECT   78,122        SVECT   70,122        SVNEW
        SVORG   70,124        SVECT   72,124        SVECT   72,130        SVECT   72,136        SVECT   70,136        SVNEW
        SVORG   78,124        SVECT   76,124        SVECT   76,130        SVECT   76,136        SVECT   78,136        SVNEW
        ; R        SVORG   68,140        SVECT   73,145        SVECT   78,150        SVECT   85,152        SVECT   88,153        SVECT   98,155        SVECT   98,150        SVECT   88,145        SVECT   88,140        SVECT   98,139        SVECT   108,138        SVECT   118,136        SVECT   124,135        SVNEW
        ; L        SVORG   68,120        SVECT   73,115        SVECT   78,110        SVECT   85,108        SVECT   88,107        SVECT   98,105        SVECT   98,110        SVECT   88,115        SVECT   88,120        SVECT   98,121        SVECT   108,122        SVECT   118,124        SVECT   124,125        SVNEW
        ; Legs        SVORG   120,128        SVECT   114,129        SVECT   104,129        SVECT   94,128        SVECT   94,131        SVECT   104,132        SVECT   114,132        SVECT   120,133        SVNEW
        ; Horns        SVORG   74,146        SVECT   68,148        SVECT   77,149        SVNEW
        SVORG   74,114        SVECT   68,112        SVECT   77,111
        SVEND
About the Author
Nick A. Bild, MS
