... I mean I hoped this would be the response but i didn't think it would actually happen. A short article the project but there really isn't more to say https://hackaday.com/?p=587271 and also talked about on the podcast https://hackaday.com/?p=588642 (16 minutes in for 2 minutes) complete with messing up my name thus giving me a new name. Thank you.
Special thanks to Kuba Sunderland-Ober who gave great suggestions in the comments. In the long run i will be trying to implement the 2 color LED and adjustable reference points but for now i will try to
a) control LED current and
b) turn it into a PCB
so.
Current control
The PCB
I'm using KiCad for this. Nothing interesting to show jet but i'll talk about some things i'm thinking about.
- connection to the breadboard
my last method was...unreliable. I am considering a spring loaded connector that feels like it could get pricey but i am not clever enough with mechanics to come up with an alternative so i might have to bite the bullet.
- power
last time it was a LiPo battery connector but needed to be driven from a controllable power supply because i added it last minute. This time i'm thinking USB connector.
- negative voltage?
for the opamps when the signal is close to 0V.
