The overall size of the chassis was determined by the size of the tracks I could get. I found these Lego compatible ones on aliexpress.
![](https://cdn.hackaday.io/images/5415151695905477377.png)
I also wanted to make sure I could fit different types of battery pack inside, mainly a pack of 6 x AA, like this:
![](https://cdn.hackaday.io/images/2517291695905932789.png)
AA batteries are cheap and easy to get hold of and there's a good chance that the students will already have some at home that they can use. Hopefully they would have some rechargeable ones, which of course would keep the cost down.
I also wanted the option to use Lipo batteries for more advanced users.
Here's the first laser cut prototype of the chassis.
![](https://cdn.hackaday.io/images/619811695906566680.jpg)
![](https://cdn.hackaday.io/images/520221695906585787.jpg)
The top cover has a tool-less quick release mechanism so you have easy access to the electronics inside.
![](https://cdn.hackaday.io/images/3702641695906934626.jpg)
The mounting plate inside has lots of options for different development boards.
![](https://cdn.hackaday.io/images/7222461695907102839.jpg)
Here's my Pi Zero sized board:
![](https://cdn.hackaday.io/images/9765321695907168913.jpg)
And here's the A+ sized board:
![](https://cdn.hackaday.io/images/1995131695907203233.jpg)
The underside with the bottom panel removed with space for 6 x AA's of a 3s Lipo.
![](https://cdn.hackaday.io/images/528631695907664583.jpg)
