April 29, 2023 - Cleaning up some of the clip leads and moved the SR Latch to the main glass board. Now three days without any bit flip errors.
The SR Latch is now located at the lower right with the black reset switch to the right of the red Led. The toggle switch selects between Write and Read and the red push button switch left of the toggle sends current to the selected core via the clip leads. The clear white Led at the far right indicates a flip of the selected core.
