[M] Using Fusion's renderer to simulate colours
A project log for Coaxial8or [gd0144]
Full-colour FFF? Multi-materials with unparalleled interlayer bond strength? Abrasives without abrasion?
kelvinakelvinA 02/28/2024 at 10:010 Comments
Transparent Cyan, Cyan + White, Cyan + Magenta + White, Magenta + White, Transparent Magenta
Seems that the most believeable result is to use a Polycarbonate material with the following settings:
In other words, I'd need deep, transparent, CMY filament.
Also note that I had to offset faces between materials by 0.001mm for the render to show up correctly.
