[M] Print-in-place cooling duct
A project log for Coaxial8or [gd0144]
Full-colour FFF? Multi-materials with unparalleled interlayer bond strength? Abrasives without abrasion?
kelvinakelvinA 11/10/2024 at 16:070 Comments
I decided to just go in and scribble something up for the fan duct. In my years of FFF printer upgrading, I've always dislike having to design them since they usually need to be more organic. To my surprise though, this duct came out better than I expected. It's effectively invisible from the front, giving the coaxial hotend assembly a very minimalistic and open look:
Design methodology
So I first decided that I was going to go back to the symmetrical-bolt mounting of the 6028 fans, and with the hotend holder now entirely made of metal, it can also help with heat dissipation. I then noticed that there'd be more space above than below the cooling 6028 so I pointed it upwards.
Then, similar to how I'd go about solving a maze, I started thinking up ideas on how the duct would start and end. I knew that the rear of the Coaxial8or was the most suitable location for the duct output. It also looked like a revolve would be beneficial to cool from multiple directions. I gladly found out that Fusion supports lofting from such a curved face:
I found that it was better to untangle the loft first and apply tangency second.
Very rough proof of concept
I went on to refine the geometry so that it was at least 3mm or so from anything else and didn't stick out beyond the bottom wheel bolt:
