Turns out that these tubes for the PTFE are so wide that the idea I had would mean that there would be almost no fin surface area.
The solution? Designing the heatsink infront of the tubes, similar to the metal part of this BMG extruder:
For the most part, if I remember correctly, air goes around cylinders relatively uninterrupted, so hopefully the airflow is decent.
For the PTFE compression fittings, I've used the Fusion360 hole feature, with a bottom angle of 60 degrees, thread depth of 6.5mm, total depth of 7.5mm and thread of 8x1.
I also increased the walls around the threads to follow this recommendation:
