These 23mm motors come with their own cable, but since it's Dupont-terminated, I'm likely still going to get XH-terminated cabling. Dupont seems to work fine on the 4-in CR600S though so perhaps I can save £3 and just make sure they're cable-tied in place to remove the risk of a loose connection. Nah. It's £3.
Another benefit is that this motor is much more common, meaning that there's a higher chance of reproducability.
I've designed a 4mm spacer so that the motors can be mounted onto 2020-series 4040 extrusion:
I'm going to see if I can get it laser cut in 4mm acrylic along with the 1mm PTFE.
Surprisingly, the BOM doesn't change all that much at all.
kelvinA
