[X] Channel 1 and 8 leak, and aluminium foil around cartridge
A project log for Coaxial8or [gd0144]
Full-colour FFF? Multi-materials with unparalleled interlayer bond strength? Abrasives without abrasion?
kelvinakelvinA 09/29/2024 at 17:100 Comments
I tried a print without the gasket and I got leaks specifically in Ch1 and 8, so a new clamp plate in steel is needed:
The images below is the result I got though, which does seem promising. I decided to only print with the top extruders (Ch1, 4, 5, 8) and the colour change does seem faster than R0:
In other news, I tried to use foil to reduce the amount of air between the cartridge and c8or, but was unsuccessful:
Folded the top edge so that I had a straighter edge to work with.
This is about half length, which was much to much.
I removed most of the foil, and even then the cartridge wouldn't insert.
Rich text editor
