[T] Zirconia heatbreak?
A project log for Coaxial8or [gd0144]
Full-colour FFF? Multi-materials with unparalleled interlayer bond strength? Abrasives without abrasion?
kelvinakelvinA • 06/20/2025 at 22:41•0 Comments
I was scrolling Amazon, searching for ceramic heaters when I stumbled upon a ceramic heatbreak, which is not something I've seen before.
I thought ceramics would be too heat conductive (I mean, they make heaters with it) and too fragile to work, but if it's not the case, it would make a lot of sense since ceramic bearings have even lower friction than stainless steel ones, so perhaps that low friction translates to polymers. I did more searching on AliExpress and found out that Fysetc  and Trianglelab both make such heatbreaks, and I was surprised to find out how low the thermal conductivity is:
Trianglelab conveniently has a section view and were able to tell me that the tube is "tightly fitted". Comparing pixels, I estimate that the OD of the tube is 2.9mm.
The first tubes I found were low-cost but also had a matte surface finish. I then found some precision polished zirconia tubes in a variety of sizes, most notably 2x4x16mm and 2.05x3x25mm.
The only thing is that this costs £2 more than what Fysetc charges for their entire heatbreak. £7 for a 2.05x3x25mm tube implies £3.50 for a tube half its length.
I looked into it and, as I probably should've known, "ceramics" is about as precise as saying something is made of "metal" or "plastic". On AliExpress, there seem to be 2 types: Alumina and Zirconia. The former is 10x more heat conductive at 27 W/(m.K). NF goes one step beyond and uses "aerospace materials" for their NF Zone, which has a removeable black heatbreak so I don't even know what it could be:
Source, who tested that it was possible to print PLA without a cooling fan and not experience clogs.
On AliExpress, there are also quartz capillary tubes which might be a cheaper alternative that has a similarly low thermal conductivity, but they likely would be too fragile.
