More Debugging, Better Layouts
A project log for A+ Split Keyboard
Over 104+ Key Split Keyborad
ironparkIronpark • 06/11/2023 at 14:05•0 Comments
After exploring the prototype board for a while, I came across a few hardware errors. This prompted me to incorporate debugging ports and make some adjustments to the layout for the case design. While fine-tuning the board design, I also took the opportunity to make some tweaks to the keyboard layout.
I modified the keyboard layout for more keycap compatibility, easier PCB routing, and some usability.
- Placed the knobs on both sides for usability.
- Modified the key placement to provide additional space for the joystick position.
- Used a more common and readily available keycap size for the spacebar.
- Applied multilayout to some columns (more keycap compatibility)
