Goals:
Support stock Ender 3 (or similar machines)
Use the nozzle touching the bed as the probing mechanism
Cost less than $10 per probe
How it works:
This replaces the stock X carriage of the Ended 3 with a custom PCB. This PCB has a strain gauge built in that can sense the force on the nozzle. When the nozzle pushes against the bed, it outputs a trigger signal, which goes to the mainboard.
mayukhnath
RoGeorge
Ron Light
advancer01
Vítor Barbosa
Hi mayukhnath, is there anywhere to buy this pcb presoldered? I'd love to get one off tindie.
