So it begins...
A project log for The Grimoire Macropad
A macropad build that is probably more trouble than it is worth.
mrpendentmrpendent • 05/01/2023 at 03:34•0 Comments
“Every good story-teller nowadays starts with the end, and then goes on to the beginning, and concludes with the middle...”
― Oscar Wilde, The Devoted Friend
I probably should have started this project log back when I actually started the project. But in school, they did teach me to begin a story en media res. Therefore, I'll start here, and add in flashbacks later.
First I put the 4148 diodes on my PCB (there will be a flashback about the board). I don't know what they are for, but this guy seemed to think they were necessary (his article was the one that inspired me). And at about a nickel each, I don't mind.
These are a little rough.
Because these were the first diodes I have ever soldered onto a board in my life...mistakes were made.
I Have Made Huge Mistake GIF - I Have Made Huge Mistake I Have Made A Mistake GIFs
To make it worse, I really messed up the mounting of the pin headers for the Pico. So badly that eventually, I just gave up on that one and started on a fresh PCB. I suspect I'll be able to save the previous one, but not right now. Like the noble shark, I must keep moving forward or I will not move forward. Excelsior!
Today, I FINALLY got the parts I had been waiting for--the hotswap sockets.
Jeepers these things look a lot bigger online!
After a bit I managed to get them on...
It's hard to tell, but these have only been soldered on the right-hand side.
One tries to make a break for it!
Once I got them all on, I worked on the pin headers, then the Pico.
All dressed up--although unarmored
The sharp-eyed out there will wonder about the pad in the upper right hand corner. That's for an LED, but I don't have it just yet.
And that brings us to the current state:
With Akko Lavender Purple switches, and the flat keycaps (without the clear hats)
So the next steps:
